Alright I just bought my bike a month ago used from hd it's a 06 SG and notice small oil spots leaking from the primary casing. I have been trying to read up on it but not too much luck. Anyone have suggestions?
Hard to say without pics of the leak but I would clean the area with a degreaser. You should be able to see where it is coming from after it sits for a while.
I'd go the cheap way 1st & check things that could be loose like the oil filter, drain plug o ring, derby cover o ring, trans cover bolts loose, plugged trans vent hose.
