Any issues with mixing tire brands?
I am interested in putting a Michelin Commander on the back of my10 EGC. The dealer tells me I will have performance issues especially in the rain since I have a Dunlap on the front. They said with different tread patterns the handling would suck. I have a 19" 3,5 on the front with 1K miles and a 180 on the back. Does it really matter? If you have mixed brands let me know what you think.
Tire experts do recommend that front and rear motorcycle tires be matched. I've seen the same said for performance cars as well. If you just cruise around town here and there on nice days it might not make any difference. But for touring on all sorts of roads and sometimes in bad weather, maybe listen to the experts.
Except the first OEM tires are the same, all my tires are always mismatched. I rode in all conditions across the country every year in almost 20 years without any problem. Most of my trips are around 10k miles. Tire matching may be applied for car, but not for motorcycle, but that's just my personal opinion.
I'm thinking the difference of tread patterns is not going to make any difference, not going to effect handling.
The way it was explained to me was that different tires (regardless of brand) may heat up at different rates due to the composition of the rubber compound. You could end up with one tire that heats up and becomes stickier than the other, and that could effect handling.
Now apply that thinking to your riding habits. If you regularly do hot laps at Laguna seca, I'm thinking your definitely gonna want matched tires.
If your an old putster like me, probably not near as important.
The only tire issue I ever had was with a Metzeler ME 880, leaned over in a curve, if I got too hard on the throttle coming out, the back end of the bike would want to swap spots with the front end. Back out of the throttle in time and all would be good.
