Lowering springs with 21" wheel
Old 11-15-2013 | 07:58 PM
customsoftail200's Avatar
customsoftail200
Default Lowering springs with 21" wheel
I got my bike apart again to clean and I was thinking about putting in the Progressive Lowering springs. Will I have any clearance issues with my 21" rim? I had to relocate the fender up about 2". Thanks
Old 11-15-2013 | 08:22 PM
Hogpro's Avatar
Hogpro
Former Sponsor
How did you raise your fender? If you used brackets which ones? What year and model is your bike?
Old 11-15-2013 | 08:56 PM
customsoftail200
I used these brackets. This fender is also the lowered one that KC intl sells on eBay. The bike is an 03 FLHT with springs in both forks.
Old 11-15-2013 | 09:15 PM
Hogpro's Avatar
Hogpro
Former Sponsor
It's hard to say with that setup you have but I would say probably not a good idea. Of course without seeing the bike it is impossible to know. If you had the stock fender it would be fine.
Old 11-15-2013 | 09:21 PM
customsoftail200
But if the fender is lowered, that makes it closer to the tire and that would give more clearance. So if you think a stock fender would work with those brackets then mine should fit, right? Or am I not understanding you correctly?
Old 11-15-2013 | 09:31 PM
customsoftail200
This is how it sits now...
Old 11-16-2013 | 10:42 AM
0ldhippie's Avatar
0ldhippie
The fork bottoms out at the same place (ya just lose the 1" of travel) so I don't see where there would be any clearance issues? I would do the racetech kit with shorter dampers and gold or Ricor valves to keep some ride/handling over just cheap progressive springs.
Old 11-16-2013 | 11:25 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The question is with the fender where it sits now which is not stock location how much if any clearance is there when the forks hit full travel. If the fender really sits 2" higher than stock than it is questionable.
06SGWA
02-23-2015 09:01 PM
MartinSporti
2014-2023 Touring Models
07-23-2014 03:05 AM
little squirt
02-25-2013 03:12 PM
JRandall
07-22-2012 08:48 PM
youngrider
07-23-2009 03:04 PM
Quick Reply: Lowering springs with 21" wheel
