Matching inner batwing fairing
You should be able to have it painted for $100.00 - $150.00.
However, it is quite a bit of work to take off and put back. Search the threads here, several guys have posted excellent step-by-step directions with pictures of how to do it.
As an aside, I would take pics of the innards of your fairing, the wiring and cable routing etc, before you take everything out or off. My indy service place hired a new mechanic, he installed my painted inner fairing, ran several wires wrong, they rubbed together, caused a short in the starter wiring, dead bike........ Luckily, my dealer ran down the problem and fixed it under warranty.
If you have the dealer put the new inner fairing on if you buy it from them, they will charge you 3 hours labor to put it on.
Good luck!
Good luck!
It's a pain in the *** taking it off and challenging putting it back on. I think the most difficult part was re-installing the ignition. My dealer also charged $600 for it to be done. But I removed it, took it to a local painter here in North Carolina and he painted it as well as some tweeters and repaired a small hole I put into it using a drill (don't drill and drink). He charged me something like $275 or $300.00. If I had to do it again, sure I can but seriously, it was a pain in the *** removing it.
I paid the dealer $500 for plus the labor for them to take it off and put it back on. Also had the bars changed out and the 1k service done at the same time. The reason mine was so expensive was because i had them do two tone big blue pearl/vivid black with matching pinstripe. Figured for the price two tone wasn't to bad. Got me exactly what I wanted for less than a solid one from the moco.
