Heated grip install directions????
Old 11-12-2013, 05:31 PM
Just Me's Avatar
Just Me
Just Me is offline
Ya, have the stealer do it, the only want $200 bucks to install!!!!!!!
Your talking close to $500 for heated grips! That's as ridicoulus as the price of a new bike. Harley must be making trillions off us dummy's!
Old 04-30-2014, 04:31 PM
ardakota's Avatar
ardakota
ardakota is offline
I am hooking up the basic black heated grips to my 14 ultra with the accessory connector my grips have a red and a black wire going back to power source which wire do I connect the red to the violet/blue or the red/blue wire on the accessory harness?
Old 04-30-2014, 04:41 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
the accessory harness should have an orange/red wire and a black wire.
red - orange/red
black - black
Old 04-30-2014, 04:54 PM
ardakota's Avatar
ardakota
ardakota is offline
red - orange/red
black - black
the colors on my accessory cable are different the directions say the violet/blue is igniton/accessory power. Im assuming that is the switched wire and the other wire is red/blue says its battery power I assume that's always hot.
I am assuming the grips should be hooked up to the switched wire.
Old 04-30-2014, 04:56 PM
UltraNutZ's Avatar
UltraNutZ
if you have a test light or meter, check them out before plugging anything into them if you're unsure.
I would not connect heated grips to the battery so yes to the switched/accessory wire
Old 04-30-2014, 05:13 PM
ardakota's Avatar
ardakota
ardakota is offline
I will check it with the meter when I get around to putting them on. There sure aren't any directions much to go by its like Harley made the accessories but haven't got around to making instruction sheets.
jskoland
08-13-2008 01:55 PM
cafrag
04-15-2008 02:05 PM
Bluerose
12-29-2007 10:40 AM
charlesk
10-10-2007 08:33 PM
jackyl
09-17-2006 12:06 PM
Quick Reply: Heated grip install directions????
