Floating Brake Rotor
Old 11-10-2013 | 06:24 AM
FL-kruzen's Avatar
FL-kruzen
Default Floating Brake Rotor
I just installed a used Thunderstar rear wheel that has a floating rotor. The one I took off was not. What is the difference? Is one better than another?
Thanks
Old 11-10-2013 | 06:29 AM
jmacdonald5's Avatar
jmacdonald5
...a "floating" rotor can actually move a little when it's squeezed between the brake pads...the idea is that it kind of "centers" itself each time it's squeezed between the pads, thus insuring that it gets equal pressure applied from each side of the brake caliper...so in a nutshell...yes..it's a little better than non floating...but not something you have to have...just a little upgrade is all...
Old 11-10-2013 | 06:36 AM
Stiggy's Avatar
Stiggy
Good explanation. (I think that they last a little longer too.)
Old 11-10-2013 | 07:24 AM
FL-kruzen's Avatar
FL-kruzen
Thanks for the explanation. I got an upgrade and didn't know it!
Old 11-10-2013 | 12:32 PM
grbrown's Avatar
grbrown
One of the reasons for floating rotors is to isolate the heat build-up in the rotor from the hub and bearings. I have had floating rotors front and rear on my Glide for over a decade now and they seem to provide improved braking.
Stomper-63
07-06-2020 04:11 PM
Beatz
General Topics/Tech Tips
13
10-19-2015 07:37 PM
budlite282
08-11-2013 09:05 PM
Stomper-63
Wheels/Tires
11-26-2010 04:28 AM
langlois1
07-30-2008 08:30 AM
Quick Reply: Floating Brake Rotor
