Belt tensioner tool?
!/2" x 6" bolt, nylon locknut and a hardware store spring that fully compresses @ 10 lbs of pressure. Drilled a 1/2" hole thru a 3" piece of aluminum stock (could also use 1/2"ID PVC pipe) and you have yourself a homemade tool that cost around $4! Hold the head of the bolt against the belt while holding the aluminum and compress the spring and check deflection. Simple tool HD gets $35 for.
We see much debate on whether the belt should be tight or loose, but the tool enables us to get it just right! It is easy to use and will last a lifetime. Simples.
$21 no brainer, also works on the old style car belts.
The factory tool works by pushing up on the belt from underneath. The swingarm and all manner of other stuff gets in the way of pulling upwards!
