Anybody lose their lighter from their batwing?
Old 11-06-2013 | 09:38 PM
lakedrum03's Avatar
lakedrum03
Originally Posted by StrokedNBored
Lost mine somewhere in Ohio... got a new one in Michigan.
The one you bought in Michigan a lot slower than if you would have bought on in Ohio.
Old 11-06-2013 | 10:07 PM
Michael Motorcycle's Avatar
Michael Motorcycle
I probably bent the tabs when I plugged my GPS in there. I'm getting the cover now.
Old 11-06-2013 | 11:33 PM
lh4x4's Avatar
lh4x4
Somewhere in the past week I lost the one that came with the 10 Ultra. Never used it or pulled it out even. Got the bike in Aug 09. So four years, three months and 30,000 miles it decided to escape. Bought a new one. Now I realize that there is a cap to plug the stupid hole.
Old 11-07-2013 | 07:48 AM
FL-kruzen's Avatar
FL-kruzen
Originally Posted by lp
You should disconnect the battery or pull a fuse or something first and then look into the socket and locate the two tabs that grasp whatever you insert into there (a lighter) and using a small flathead screw driver bend them towards the center of the socket. That pretty much does it.
Just take a look and you'll see what I mean. Simple.
lp
Ok, got it. Thanks
Old 11-07-2013 | 07:51 AM
60mike06FLHX's Avatar
60mike06FLHX
A few years ago my wife and I were out for a day trip, we stopped to eat lunch in the old section of Newport, KY. Very rough streets as a lot of old historic streets are. After lunch we had just pulled away from a stop sign and I was trying to shift from second gear. I could not shift up or down. I managed to get to a local dealer thinking my transmission must be out, after about ten minutes the tech came out and said I didn’t know you smoked Mike. It seems the lighter had come out and bounced under the shifter rod and was stuck, as I tried to shift it just bent it up and stuck it in tighter.
I changed it out to a small flash light.
Old 11-07-2013 | 07:55 AM
biil9's Avatar
biil9
its long gone.
Old 11-07-2013 | 08:58 AM
Geoff's Avatar
Geoff
Hertz, Avis and Alamo offer the best value in cigarette lighter socket covers... if you catch my drift.
Magnum2010
05-17-2018 07:05 PM
Mr E
11-04-2012 07:16 PM
Dailydriver06
11-23-2011 12:02 PM
farmersemail
EVO
20
08-31-2011 12:55 PM
Sleeps In Trees
02-10-2008 02:36 PM
Quick Reply: Anybody lose their lighter from their batwing?
