Auxiliary knob position
11-06-2013 | 01:56 PM
Auxiliary **** position
Does anyone know why from 09 on the lights stay on when switched to auxiliary. Makes it hard to listen to tunes at the motels at nigh.
11-06-2013 | 02:01 PM
Just turn spot switch off
11-06-2013 | 02:04 PM
Quote:
Originally Posted by
prezflyr
My 12 doesn't. Turn to aux and lights go off and stereo plays and anything through the Acc switch works. Same on a buddies 09
11-06-2013 | 02:16 PM
Not sure if it has to do with the harness to keep spots on with high beam.
11-06-2013 | 02:45 PM
davidwruth
I believe that is true
11-06-2013 | 03:59 PM
Guitardude
OP....have there been mods done to your wiring? Pretty much the same on any newer bike I've seen.
11-06-2013 | 05:10 PM
Guitardude
Something is off??
11-06-2013 | 05:14 PM
But not his lights evidently.
Sorry couldn't resist.
11-06-2013 | 05:30 PM
If you or original owner installed a run/turn/brake auxiliary unit the rear lights stay on with accessory, but not the spots or headlight.
11-06-2013 | 08:36 PM
The harness to make spot run with high beams will cause the spots to stay on when on acc. It is actually getting power from the acc side. You have to turn the spot switch off.
