battery charging
I ended up just installing my B/T cable that I removed from my old bike and routed it to a better location. I considered trying to re-route the one under the left side cover but I wasn't too fond of it possibly dropping down in the gap at the back end of the primary / belt area. So, I now have 2 but the factory one is stowed and not used.
His bike is a 2014 and the Factory Installed Battery Charger Harness is located under the left side cover and the length is not adequate to reach over to the right side of the motorcycle. As I suggested to him, just add another harness to the battery and he can locate it to wherever suits him the best. I also have the harness that I installed routed near the dipstick area as you suggested and do not use the factory installed one. It's nice that Harley installed a harness from the factory but they could have made it more User Friendly.
I don't know mine is a factory tender pigtail you can buy a new one thru Deltran Battery Tender
http://batterytender.com/products/accessories.html
get these:
http://www.motorcycle-superstore.com...ount-connector
http://www.motorcycle-superstore.com...x-jack-adapter
http://www.motorcycle-superstore.com...x-plug-adapter
use for tender and heated gear
thanks all for the input....
