RG outer headlight cover
RE: RG outer headlight cover
Guys! It's too easy! There are four tabs, two on top, two on the bottom of the headlight cover. Take a putty knife and gently pry up the cover from the bottom about an inch from the corners. Wiggle it out. After some practice, you can do it with your fingers. I take mine out on a regular basis and clean and wax the inside. Novus plastic polish is great stuff for the outside on a semi-annual basis. Be sure to get the bugs off with a goodly shot of water.....you can scratch that plastic.
this is like a lot of things in life - its easy "once" you see how it is done - be VERY careful when prying - this is a great way to chip the paint on the fairing. Just for info - when I did the swap from EG to RG - and I installed the headlight lens - it fit so snug - now way was this going to come off by following the above instructions - I am not saying the instructions above are wrong - these guys are right on - however, your lens could be as snug as mine would have been, had I just pushed it together - instead - I spent some time looking at why it was snug - turned out to just be layers of paint in the slot - with a jewlers file - I made a few passes and the lens went in like butter and can now be removed as above instructions...
Try and find a buddy that has done this before and have them show you the trick
The putty knife was used once! And it was very old!My paint was not harmed. Seriously, it is easy to get the lens to pop-off by lifting up with your fingers and pulling up and away. I guess an old plastic ice scraper or popsicle stick or other relatively harmless lever would certainly suffice if it proved stubborn.
Good idea on the paint removal in the slots, BTW.
ORIGINAL: harley0711
Got home from work and read all the posts. OK, sounds easy enough. Tried with fingers, now raw.
Tried popsicle sticks, broke 3 in 10 pieces. Tried plastic thingy, nope. I'm very mechanical, auto tech by trade, whats goin on here?
Got my old broken putty knife out, OH NO! Started prying at upper left tap with towel as protector, harder, harder, BOING POP SNAP, cover comes flying off and hits me in the face.
Nearly S&%T my pants. No damage to cover or fairing. Cover waxed up and clean.
Hope I cleanded up the slots enough because it went back on awful tight?!?!
THANKS ALL, could not have done it with out you!
