Oil leaking out of the Carburater and Air Filter?? Whats the cause?
Top End
I was told that this helps with top end oiling...True or false?
It has no effect on oiling.
It does help reduce carbon deposits in the combustion chamber and the top of the pistons though. The oil inducted thru the intake doesn't burn completely and creates deposits. These deposits will super heat faster than the material it's attached to. Super heat to the point of glowing and touching off the air fuel mixture before the spark plug does it. This is extremely bad for the engine. It's one of the primary reasons why folks who do not reroute that oil mist have "pinging".
If you put exactly 4 quarts in, its probably over filled a little. You need to actually check the level on the stick. 4 quarts is a completely dry motor spec.
My '08 TC seeped oil from the breathers into the throttle body and pooled in the manifold between each cylinder. The oil would also slowly coat the air cleaner and finally show itself on the outside of the air cleaner and parts below.
I inserted steel brake tubing into the breather holes to direct the oil more into the throttle body. While that had some success, the oil just seemed to form even larger puddles at the bottom of the manifold.
My 2012 TC began to show essentially the same oil issue not long after I put it into service.
This time, I pulled the black tubes from the rear of the air filter (leaving them attached to the breather ports) and wrap oil absorbent material around the bottom open end and just let the black tubes hang behind the AF. I then plugged the two holes on the back of AF.
I ran the bike this way all this summer checking things from time to time.
The other day I checked my rigging again. I unwrapped the black breather tubes and noticed only a couple drops of oil in the material. No oil on the AC back plate or AC housing.
Maybe, just maybe, the intake creates enough vacuum to draw some of the oil mist out of the heads and into the throttle body creating the often-reported oily mess. By not subjecting the heads to this vacuum, maybe the oil is not being sucked out creating the problem.
And for those wondering, I only ran the oil level about half way up the dip stick as my "full" mark on both bikes which is not even close to a full gallon of oil.
Sorry, no pics...
I've read from other MC sources it was highly recommend to do this? Not to allow gas and oil to mix at the carbs.
Instead of "oiling" I meant its for "top end lubrication". I stand correct as otherwise noted as I was told this at an HD dealer...Go Figure.
"I thought "pinging" came from an improper balance of fuel mixture and air or to aggressive timing settings?
