Tri bar running/brake light for street glide install question
I just bought a 2014 street glide and I am swapping out the running light for the brake light/running light accessory part and I remember when I installed the same on my 2012 it was a pain because of tight area for fingers for removing those star screws that mount unit, what did you guys use to get into that tight area to remove mounting screws?
Just did mine last week on a 2014 SG, (1) remove cover on the back it just snaps off,
(2) unplug wires,
(3) get #20 torx-up on top inside fender undo torx screws, remove running light,(4)get
run stop brake light in place in fender, (5) plug wires into both ends, (6) put Torx screws
back in holes do not over tighten, last replace cover it just snapsback on.
(2) unplug wires,
I took the "partial" fender/filler off the rear fender (1 bolt underneath the fender - loosen it up is enough) and the 2 x 3 bolts behind each saddlebag (I had to glue 1 clip on anyway). took 2 connectors off and voila... then it is easy to unscrew the 2 torq screws.
I modded my own stock tri-bar to do run/brake... a lot cheaper than buying the MoCo version....
planning to mod 2 more I got laying around (on is pre 2010 I believe, it does not have the 2 connectors installed). If anyone is interested in them let me know via PM...
<-- Where do they come up with these?
Thanks guys I'll try jacking the bike up and use torx with ratchet last time I found using a torx Allen wrench too much work!
one thing I didn't do was
