new steering head bearings
does anyone else think a ball bearing in the steering head will get flat spots in them. don't have much faith in any of the harley sealed roller bearings. i guess they weren't selling enough of the tapered timken bearings. i think you will see some failure of this new setup. why change something that's worked so well for so long, same with the wheel bearings. if it ain't broke quit trying to fix it.
Received 4,632 Likes
From what I heard the 2014's don't need lubrication because they are a closed sealed unit. My service tech said that the bearings would be changed after so many miles as per the service manual. Makes sense, just like ball joints, bearings etc on a car or truck, right???
Who boy... I can remember when the car companies went from tapered to sealed bearings for the axles and spindles. For a few years, dealers had 55 gal drums out back filled with old sealed bearings. Finally this stopped as the car companies dialed in what the bearings need to be.
I truly hope this 'learning curve' has already been went through on other bikes.
Received 49,844 Likes
