new steering head bearings
11-02-2013, 10:27 AM
Quote:
Originally Posted by
Uncle Larry
FWIW ... Roller bearings have a much greater contact area than a ball bearing does.
That's great but in this application the ball bearing load is needed vs a straight roller bearing load.
11-02-2013, 10:32 AM
bagman1
They are still tapered.
lp
11-02-2013, 12:35 PM
lp
11-02-2013, 01:08 PM
lp
so what you are saying is they are tapered sealed bearings?
11-02-2013, 02:53 PM
hardheaded
They are tapered rolling bearings that require service using special purpose grease, with separate dust shields.
11-02-2013, 03:22 PM
lp
Good. I have, admittedly, NOT read any of the bulletins on the 14s yet. Thank you sir.
11-04-2013, 08:02 AM
i wonder if any grease would get to the bearings if you drilled and tapped the neck on the frame?
11-04-2013, 08:12 AM
hardheaded
That has always seemed to me as an easy way of loosing a whole can of grease, 99.9% of which will serve no useful purpose and add a couple of pounds to the dead-weight of the bike!
11-04-2013, 04:20 PM
grbrown
yea,but after getting it full on my 2 bikes i can then give it a few pumps and force new grease threw the bearings. it's gotta help.
11-04-2013, 06:26 PM
it was mentioned on another site the head tube is not blocked off inside, so you would be trying to fill the whole frame with grease. Mike
