WHEELS TUBE OR TUBELESS
JUST A QUICK QUESTION? I HAVE A 2003 RKC I HAVESPOKES WHEELS I,M GUESSING THERE STOCK.I,M NO SURE BUT I THOUGHT THEY WERE TUBELESS, A FRIEND TOLD ME YOU CANT HAVE A TUBELESS TIRE ON SPOKE WHEELS THAT THEY HAVE TO BE A SOILD WHEEL ANY HELP ON THIS MATTER WOULD BE GREAT
THANKS
THANKS
RE: WHEELS TUBE OR TUBELESS
If you have spokes you have a tube. Tubeless tires are for cast wheels. Ihad to change mine out because I liked the idea of being able to plug a tire to get me to a dealer on the road and with my spoked wheels I would have had to pull the tire off and patch the tube. Since then I have went to a 21/18 set up that is tubless. Hope this helps.
Bobby
Bobby
You will be able to tell if you have a flat.
Tube = flat tire, call wrecker service, haul to dealer wait several hours for repair, if lucky to happen during business hours and near a dealer.
Tubless= Plug tire w/5.00 plug kit, inflate with 20.00 12 volt air pump, back on road it 10 minutes.
10 minutes to do a plug and inflate might be a little optimistic there Gunrunner, but you are right , road side plugging isa lot better than finding a tow on a weekend 100 miles from a dealer. I did one a year ago, probably took better part of an hour, but then I was on my way.
What do you use in your plug kit ? Mine is the "plug n go" kit with CO2 inflators topped off with a Walmart 12v air pump.
