Changing from a 130 to a 180 on a 2001 FLTRU
I need a little help from those who have done this. I have been down this road before with my 2001 FLHT by using a skinner drive sprocket and belt to allow for a 150 tire. It worked but left only about 1/16" between belt and tire and no it dose not rub believe it or not.
So now I have a Road Glide and it's also an 01 and I'm wanting to move to a 180 tire from the stock 130. After doing some more research I found that if I used a drive sprocket and belt from an 07 model (which is even skinnier than what I used on my FLHT) than I would be able to fit a 180 in there.
Now for my dilemma, The fender width is now the issue and or the the strut width. I'm changing the fender to a stretch fender, but I wanted to know if anyone reading this has done it so that I can get some experienced advice before buying the tire and fender.
Thanks,
Thanks,
Ok, so you have confirmed what I have heard about klock werks. I think the chain conversion is good advice also. Can I ask you what fender you are going with? Were you able to get the werks fender before discontinuing it? Also if I were to go over the struts with a fender does it eliminate docking hardware for backrest etc...?
see here
https://www.hdforums.com/forum/touri...-and-tire.html
or you can use the 07 SE Road King rear fender. it is a direct bolt on but requires you change the tail light
see here
I am running a 180 on my 00 RK, I took a 09 fender and scalloped it to fit between the frame, from the rear bag support strut forward and built a metal fascia to hide the scalloped part of fender, or you can also check with Russ Wernimont designs RWD they have a rear fender kit also for the 180 fitment that doesn't look like a overlay, it fit between the frame rails. I am running a chain with a 120 c.i. motor. the easiest would be the 07 S.E. Road King fender, that bike came out with a 180/16 on it.
Yes it will get in the way, the 180 will not fit in the old fender. just to try one time couple years back, I cut the old fender right down the middle to spread and welded a section in to support the overlay, then the overlay fender would not fit because of the curvature spread out on the old fender.
this is how tight the 180 fits
