Help with new noise???
Old 10-26-2013, 01:55 PM
blackflame's Avatar
blackflame
blackflame is offline
Default Help with new noise???
My bike just started making a whining noise, sounds like a turbine or a skill saw. I noticed it at around 30-40 and then it would die down as I slowed to a stop??? Pull the clutch in same noise. Bike has around 12k 06 EGC with stage one. Any help would be appreciated.
Old 10-26-2013, 02:17 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,818 Likes on 3,172 Posts
06? Usual suspects cam chain tensioners should be checked, (but at 12,000 miles that would be a record for early failure.) '06's also didn't have the '07 and later primary issues but inner primary bearings do fail sometimes. Comp nuts loose would also give a knocking sound at idle though.
What side of the bike is whining?
Old 10-26-2013, 03:12 PM
blackflame's Avatar
blackflame
Hard to tell, it's not a loud whine, could be coming from the front... It was fine then about 20 minutes I heard it and didn't know wth it was.. Thought I would come here first .
Old 10-26-2013, 03:18 PM
rooti's Avatar
rooti
rooti is offline
the primary chain is too tight
Old 10-26-2013, 05:14 PM
blackflame's Avatar
blackflame
Shouldn't be 6500 miles so far this year and never heard it before or did I adjust anything?
Old 10-27-2013, 01:02 PM
blackflame's Avatar
blackflame
Giving this a bump..
Old 10-27-2013, 02:20 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Wheel bearings?
Old 10-27-2013, 02:48 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,013 Likes on 577 Posts
I had a similar noise coming from my front end, turned out to be the brake pads.
Old 10-27-2013, 04:44 PM
blackflame's Avatar
blackflame
I thought that at first, but the whine is the same braking or not. And I think if it was the wheel bearing braking would change the sound also.
Old 10-29-2013, 12:36 PM
blackflame's Avatar
blackflame
Update on noise, still getting it at around 30-40 but if I give it some gas it goes away, let off gas comes back, pull clutch in goes away most of the time. Buddy said check the drive belt and primary chain tension??
Quick Reply: Help with new noise???
