Beware of the Clunk when starting an 07
I had noticed a sort of clunk almost like a kick back when starting my new 07 FLTRI. Didn't think much of it until Saturday night. It didn't start and after the CLUNK I hit the starter again and it made some awful noise and did not start.
Hit the button a few more times and it started right up. Took it to the dealer the next morning and it did the same think in their shop. They took the starter off and all of the teeth were ground down to nothing. Then they pulled the primary and the ring gear only had about 1/2 the teeth on it. Looks like everytime I started the bike it would take a tooth or two off. In addition, the teeth got everywhere, in the clutch the chain, basically destroyed the drive side of the bike. The general manager of the store and all of the Techs gathered around in disbelief, saying the CLUNKING is what caused this. The bike only has 600 miles on it.
RE: Beware of the Clunk when starting an 07
back in the ole AMF days, when the auto timing retard hung up, it would tear up the starter gear. basicallythe engine would fire before top center and try to run back wards and tear stuff up. going even further, inthe kick start days it would either break you ankle or throw you over the bike.
no idea today, how the auto retard works, but again back in the seventies, what yourmechanic found wouldn't have drawn a group of amazed techs, but rather a shrug.
regardless, something ain't klicking.............
Keep us posted.
I'm sure we have all been told the "Clunk" is normal....I hope you haveanother issue,something with the starter drive not kicking in all the way and its not related to the clunk.Seemswe would have heard from more by now if it was a designflaw or directly related to the clunk.Besides I thougtthe "clunk" was a result of take up in the primary chain due to the clutch driving the motor, not starter engagement?
May be a good time to get that inner Chrome Primary as long as they are tearing it a part...should be able to get a good deal on labor .
I agree... sounds like metallurgy or heat treating or tolerance or fit defect. They really need to sanitize replace all the components, bearings and such of any fine-metal pieces... a good dealer will.
ORIGINAL: gunrunner
The clunk is not starter related, its the comp making the noise. Yours is just a defective part and the only one Ive ever heard of do it. Not a 07 issue, just a your bike issue. Once fixed it will be fine Im sure.
