Found a good deal on a set of stock wheels and tires from a 2013 Road glide and wanted to know if they will fit my 2010 road king without any modifications? Anyone know? I believe the front is a 18" on a road glide, correct? Will this affect the front fender?
They should fit. What you need to know is if they are coming off an ABS or non abs bike. And is your bike ABS or NON ABS? If they are ABS and you are NON they you would need to change a couple of bearings. If they are both the same they will bolt right on.
Ok found out the wheels are coming off a bike without ABS, mine has ABS. What needs to be done to make them work?
You need an ABS bearing installed in the front wheel and one installed in the rear. The bearings are $50 each from Harley. I have no idea what they will charge to pull out to the old ones and press in the new ones.
What about an '05 Road King Custom? There are a TON of newer model Street Glidewheel take offs on Craigslist.. The wheels are more appealing then my stockers...
Reason: added some info
