Bolt pulled through on fairing
All of these are options, but if it were me, I'd be on the doorstep of the GM at the Harley Dealership. And if I didn't get any satisfaction there, I'd go to Corporate, and let them all know this is unacceptable, and you want to be compensated. Rolling over, and fixing it yourself wouldn't be an option. Final step, a letter to the dealer from your attorney. I know that all sounds like a pain, but if not you, who, and if not now, when? The GM may have a completely different take on the situation than the service dude that blew you off. Go back to where the problem originated. The fact that they had to remove the fairing for the work they did should be your foundation of inquiry. Let us know what happens.
The OP did not indicate this was done at an HD dealer.
If it were me I would not have left the repair shop until we had a resolution. You should not get your bike back worse then when you brought it there and it became your problem to fix. That kid knows he screwed it up but did not tell his boss. Proper thing to do is if it was screwed up before, he needed to document it and let you know that it was broken before he started on any repairs.
I had the same issue and I went to Lowes and found some black spacers (bring the fairing bolt for sizing) that had an extended edge on them. I had to cut down the spacers since they were slightly too long but once slipped over the bolt, they cannot be seen and keep the bolt from pulling through the fairing.
Just reporting back to let everyone know what fix I chose. I used superglue and glued a flat washer to the inside of the fairing. I also put a spacer on the bolt. So far it is holding and you can't see any repair. I am going to purchase an inner fairing and have it painted so I have a future project. Thanks for the help
