Stock seat rk flhr, how do you like it?
I had a hammock on my '10 Limited, but I use a backrest, and the description for the new hammock says you can't use a backrest with it, do you know that to be true?
I think you will be happy with the '13 RK stock seat comfort-wise.
I liked mine just fine for comfort but found it set me a little bit high so got the HD Solo Touring Seat, which moved me lower and a little farther to the rear. In future, I will probably go back and forth between the two depending on the riding situation.
Good luck with yours!
I have no problems with my 2011 with the non adjustable back rest pushing on the seat slot. My neighbor with his 2003 King has the hammock with the cable adjustable on the fly back rest and the mount had to be moved and a "kick or offset" had to be put in the backrest upright to get it to not push on the seat slot. How it pushed on the seat caused lump to push in his lower back and be uncomfortable.
