Wires in the bars
RE: Wires in the bars
My little bit of advice is that if you are going through the trouble of changing the bars, then you might consider relocating your turn signals to the front with your headlight. If you don't have the passing lamps then that's how I would do it. Buy the kit to put the passing lamps and turn signals up front like the RL Classic.
Running the wiring inside the bars is a little harder when the turnsignals are on the bars. You will need to follow the route of the exsisting wiring and disconnect them from the junction block and your going to have to lengthen them and then run them inside the bars and re-route them in the center with the other neck wiring and re-install them back into their original spots on the junction block. A lot of work, but inside wiring looks great. You are going to have to do the same thing with all the switch wiring and that is much more laboring....lengthing wire is time consuming and make sure you mark all the wires so you know where they go back to.
Good Luck.
[IMG]local://upfiles/494/44F69190078C4B79918A9F8ECBC51B18.jpg[/IMG]
Good Luck.
Thanks for the advice and help. Im heading out to the garage to dive in now. As far as my turn signals Im not sure I want to relocate them, I kind of like them on the bars. But if I run into too much trouble I may not have a choice. I will let you guys know how it comes out.
Thanks Again,
Jeff
Thanks Again,
Jeff
