Removing stuff baked on heat shields?
Old 10-22-2013 | 01:11 AM
gotwages's Avatar
gotwages
Originally Posted by TriGeezer
I'm the OP. So, I already had WD40, and bought some 0000 steel wool. Started with cold pipes, Soaked the steel wool with the WD40 and gently rubbed the baked on oil on the heat shields. It all came off almost instantly! Tried the same technique on the year old boot burns, to no success. So, used a lot more scrubbing pressure, and a lot came off. Then soaked a rag with WD40, and wrapped it around the blemish. Timed the soak by the time it took to open & enjoy 1 beer, then rubbed moderately briskly with the 0000 steel wool soaked in WD40. Success!!! No abrasion on the heat shields' chrome at all, in fact they shine like brand new. Note: larger or more persistent boot marks may require soak time of two or more beers. So, anyone want a can of MOCo boot heel remover.? No Thanks for all the replies and suggestions! Jeff
Good to hear. I learned that trick from an old rider.
twhill3
08-09-2009 08:47 AM
Sturgeon
06-04-2009 12:02 AM
rocksandgiz
03-09-2008 07:24 PM
sandr71970
Exhaust System Topics
10-19-2006 11:42 PM
Pathfinder
02-28-2006 02:20 PM
Quick Reply: Removing stuff baked on heat shields?
