Again with the chattering
Old 11-03-2013 | 07:12 PM
Texas Rapier's Avatar
Texas Rapier
I had a chattering noise on the left side of my 2009 king, don't know if it the same chattering your are hearing.
I put one of the nice him-joint shifter rods on my bike and a couple of weeks afterwards I started noticing a chatter. The him-joint had some slack in them and would chatter at certain RPM's. A couple of O-rings solved the problem.
Old 11-03-2013 | 08:07 PM
RAP's Avatar
RAP
Originally Posted by jackhis
Based on all the information that you have described, I think the compensator may be the source.
I would agree with this also.
Old 11-03-2013 | 08:21 PM
lp's Avatar
lp
Those that have had Comp issues... did yours chatter under load?
Seems like it wouldn't. I dunno...
Like a few posts above my shift linkage chattered. Replaced it with a better one with heim joints. Noise gone.
lp
Old 11-03-2013 | 10:42 PM
RoadHog659's Avatar
RoadHog659
Could be, but had the chattering before installing the SE compensator. And had it after installing the SE compensator, too. Today the chattering sounded more like knocking when I took the bike out for a spin. Hadn't been able to ride for a while thanks to Ohio weather. Quieted back down to a chatter after a few miles.
Old 11-04-2013 | 05:03 PM
TUCCI's Avatar
TUCCI
I replaced my lifter and put in adjustable SE push rods.....now the rattle happens till it warms up and after it sets for awhile.....I put louder pipes and if I really don't want to hear it I put ear plugs on. Going back to dino oil next rotation, synthetic is a waste since it doesn't even get to 3500 miles when I change it. Oh Oh did I just start an oil thread
Old 04-12-2014 | 09:24 PM
RoadHog659's Avatar
RoadHog659
Default Update
Just an update from an old thread. Don't know if it was the shifter shaft seal, or the inner primary oil seal, or the starter o-ring, or just reinstalling the compensator/clutch/primary chain ... but I heard no chattering on the ride home from the dealership. Looking forward to NOT chattering thru the Smoky Mountains next month.
Old 04-12-2014 | 10:19 PM
WB's Avatar
WB
Bet is was the compensator. I had 2 installed three months apart. First replacement lasted about 3 weeks and started rattlin on takeoff again. Finally convinced the dealer to tear down again and sho nuf.... Been about 8 months and the third comp rattles on cold mornings with initial take off.. Bottom line is the comps are bad quality.. SE are no better. JMO
GPHDXLC
08-23-2012 12:58 PM
2006ultra
06-18-2012 08:31 PM
RoadHog659
07-22-2011 05:52 PM
Pastor John
09-10-2008 02:52 PM
05HARLEYMAN
09-29-2006 06:22 PM
Quick Reply: Again with the chattering
