Looking to add Progressive 444's and Monotubes.. Advice Wanted
Old 10-19-2013 | 10:05 AM
2807's Avatar
2807
Default Looking to add Progressive 444's and Monotubes.. Advice Wanted
Howdy. Well, after further review, looks like I want to upgrade the suspension, and avoid air shocks.
When I asked "what would give me the best ride" this is the basic answer I got (Progressive's) Yes, there may be very expensive alternatives, but this appears to be a solid upgrade.
I am new to this. Any advice on "444's" or other options, and the front end Monotubes?
I have a 2012 CVO Road Glide Custom, it is 12" stock rear-shocked now.
It bottoms out so hard on the freeway that it knocks out the cruise control.
I ride very conservative and am 5'11, 195, no passengers ever. SOLO only.
Thanks folks !
Old 10-19-2013 | 10:36 AM
2807's Avatar
2807
Well, I should have "searched" first.
Lots of info out there. Looks like these will be a great combo!
If I knew how to delete this original post, I would.
Thanks folks.
Old 10-19-2013 | 12:15 PM
booch's Avatar
booch
That is the combination I have and I am happy with it.
The elimination of the fork dive is the biggest improvement and not having to check air pressure in the rears for leaks.
I did have to dial the rears up stiffer than what was recommended to give me the ride I wanted. Too soft and you will be wallowing all over the road.
Old 10-19-2013 | 02:58 PM
2807's Avatar
2807
Hey, thanks. I am about 190-195 lbs, and with the tourpack I will be adding way over the 200lb mark.
Should I get the heavy-duty springs. I read that they are recommended if you are usually near 200lbs...
I just dont want a stiff ride, but I dont want a squishy ride either.
Any advice?
Old 10-19-2013 | 04:42 PM
Groucho1's Avatar
Groucho1
Default Nope..
I would not get the stiff springs. It's not why I bought a RK. They will always swap them if need be.
Old 10-19-2013 | 07:01 PM
2807's Avatar
2807
Thanks. I will keep that in mind. Would be nice to get the standard springs and try them out. I will ask what a swap out would cost.
Good plan. Thanks
Old 10-19-2013 | 07:06 PM
sanman4ever's Avatar
sanman4ever
Progressive will swap them out for free. You just have to pay for shipping each way. They will ask you to provide a purchase receipt. Maybe that figures into them charging for a swap or not charging.
Old 10-19-2013 | 07:36 PM
2807's Avatar
2807
Great ! Can if I go with the standard shock would bottoming out be the sign that I need the HD shock?
Or would the ride in general suffer..? (and bottom out on occasion) ?
Thanks
Old 10-19-2013 | 09:02 PM
booch's Avatar
booch
I'm 195lbs and have the standard spring.
I have it set stiffer than the setting guide but still have lots of adjustment left.
I have a detachable tourpack and have loaded it up pretty good and never had a problem, but I always ride solo
Old 10-19-2013 | 10:17 PM
2807's Avatar
2807
We are the same! Thank you for this. Looks like I will go with the standard too.
Grand-Dragon
10-17-2015 12:32 PM
alienbogey
05-29-2015 12:44 AM
13bob
07-18-2014 11:15 AM
rolfsharley
11-26-2012 10:59 AM
albngore
01-06-2011 05:16 PM
Quick Reply: Looking to add Progressive 444's and Monotubes.. Advice Wanted
