Cableext Kit for ABS bikes....
I am having a hard time finding a full cable kit for my '13 SG w/ABS. I am wanting to put 14 inch Apes on her, but need to get this kit. Someone told me he thought that with the 13 the ABS was in the hub so all brake cable should be the same? Anyone know if this is indeed the case? Thanks for the help as usual.
Eric
Eric
Eric
Eric
Magnum Shielding is the way to go for your ABS equipped bike. ABS lines are in three sections you can do just two to save money (mid and upper) or all three for the complete package.
I installed 14's on mine and changed only the upper brake from abs to the bars. Will change the rest later on. It's basically up to you but the upper line is all that's needed. Replacing the others is just so they will match.
