SE pro super turner cable
Just checked mine, yes the Deutsch is a 4 pin female
HI have different info on the pin out of the cable and was wondering id someone can help me out and confirm which pin out is correct?
Originally Posted by Vetteman View Post
Yes and no, the cable from the computer to interface is a common USB printer cable, so no on this one, but the cable from the interface to the bike is the same, so yes.
Here are the pinouts if you want to make you own cable for the interface to the bike:
Numbers represent pin locations on connector:
Deutsch connector:
1 2
3 4
DB9 Connector:
12345
6789
DC to DB9: pin 1 to pin 1
DC to DB9: pin 2 to pin 6
DC to DB9: pin 3 to pin 5
DC to DB9: pin 4 to pin 8
Hope this helps,
Cheers,
Frank
The post made by vetteman about the pinout of the data cable is WRONG. The old SERT cable works as is for the new SEST. If you follow his instructions to make your own, it won't work. And his pictorial of the pinout of the Duetsch connector is wrong as well.
The correct pinout for the SERT/SEST cable is:
DC to DB9: pin 1 to pin 5
DC to DB9: pin 2 to pin 1
DC to DB9: pin 3 to pin 7
DC to DB9: pin 4 to pin 9
Only three wires are actually used, so I assume this cable has multiple uses elsewhere besides on a Harley. Pin 1 of the Deutsch (flash pin) isn't used.
Thanks for the help
Deutsch connector:
1 2
3 4
DB9 Connector:
12345
6789
Hope this helps,
Cheers,
Frank
Thanks for the help
Fraser McKenzie
16
06-19-2018 07:12 PM
94 ultra
10-15-2016 03:08 PM
mrbadlands
10-14-2009 04:16 PM
