2012 road glide battery keeps going dead
If it were mine I'd disconnect the battery from the bike's wiring, charge it (if possible), wait a few days and see if it goes dead on its own.
If ok after a wait (holds 12.6-7 V), connect it to the bike's wiring and see if it goes dead in the same time.
If so, then go looking for excess current draw from something on the bike. Pull fuses, test resting amperage draw, etc.
I had a new batt that would never take a charge...the Yuasa 1.5 A charger never went into float mode (13.2 V) from bulk charge voltage (~14.5 V), likely due to excess current flow. Bad batt...got new one under warranty.
