Inner primary bearing
Old 10-12-2013 | 01:17 PM
scglide's Avatar
scglide
Default Inner primary bearing
Has anyone installed a IPB race without the puller/installation tool? if so how did you install the race in the proper place?
Thanks ,
Steve
Old 10-12-2013 | 02:09 PM
PhatTerry's Avatar
PhatTerry
If you have a large selection of sockets, specifically one larger than the diameter of the bearing and one just slightly smaller. You can use those on either side of the primary and use a long threaded rod (thin enough to fit through the socket drive holes) and some nuts to pull the bearing out or put back in.
Old 10-12-2013 | 02:46 PM
scglide's Avatar
scglide
Thanks PhatTerry But the race and bearing are seperate, the race must be placed on the shaft in a specific location. I think I will use a depth micrometer to get the right location.
Thanks,
Steve
clarkchriston
10-26-2020 12:04 PM
DMetcalf
09-11-2015 04:46 PM
DJ Baar
09-22-2011 09:19 AM
CroK
General Topics/Tech Tips
10-15-2009 04:52 PM
