newer 18" OEM wheel on '08 SG
Old 10-12-2013 | 07:47 AM
badpig173's Avatar
badpig173
Default newer 18" OEM wheel on '08 SG
So I picked up an 08 Street Glide to replace my stolen crossbones.. I want to change out the 16" OEM wheel to a later model 18" or 19" wheel... I've seen some listed on ebay that says for '09 & above and some that say '08 and above.. what's the deal with that? I thought 08 and above were all 1 inch axles, the only difference should be whether the new wheel was ABS or not?
Old 10-12-2013 | 08:27 AM
CurtisO's Avatar
CurtisO
They are the same up to 2011 for sure. That's what I put on my 08 RG. A takeoff 18" from a 2011 Street Glide. I beleive they are called AirStrike.I did have to change one bearing on the wheel it was ABS and I don't have that option. Later I picked up a matching 16in rear from an 08 SG.
Old 10-12-2013 | 08:56 AM
AFMM3's Avatar
AFMM3
Starting in 2008, the wheel bearings are 25 mm (0.98 inch). Immediately prior to that was 1 inch bearings and axle.
Old 10-12-2013 | 09:00 AM
MikeTD3's Avatar
MikeTD3
I picked up a tire/rim/brake disk from a 10' on ebay, it was a direct bolt on.
Old 10-13-2013 | 10:27 AM
badpig173's Avatar
badpig173
thanks! thats what I thought.. but a couple of the sellers have it posted a little wrong..
Jkillings8479
09-13-2016 06:39 PM
raw
12-07-2015 06:49 PM
drumster
05-05-2014 10:17 AM
AZSN8S
01-22-2011 11:09 PM
neurostudy
01-29-2008 12:18 PM
Quick Reply: newer 18" OEM wheel on '08 SG
