2013 Flhx with ABS - 12" Monkey Bars Install
I have searched with a great deal of mixed results. I have a 2013 street glide with ABS. I've purchased yaffe 12 monkey bars to install in black. I've got an 8 over clutch cable per most of the recommendations on this site. It appears some do not specify ABS or not on the brake line.
So my question is 6 over or 8 over for yaffe monkey bars on an FLHX with ABS?
I appreciate the help. Thanks
ABS completely changes the brake line...On an ABS bike, the line goes from the master cylinder to the ABS module and then up to the brake caliper. A non ABS bike goes straight to the calipers...I hope you ordered the right line...
+6 is fine, I have 12" monkey bars and ABS, trust me this is the easiest part of the install, I didn't even remove the tank, I just lifted it and fished the new line under it, electrical tape the resivoir end of the old cable to the module end of the new one and pull it through.
