Is 1 quart oil sufficient vs. 38 oz. in the 6 spd. tranny
#31
Good rule of thumb to follow, I am the same way.
#32
#34
I still don't know how the oil level of a remote oil bag computes to more or less oil out the air cleaner but it's been mentioned on this forum many, many times as a possible solution.
Weird huh?
lp
#35
Not to mention, that oil in the motor is serving as a coolant as it goes through the system and the oil cooler, unlike the sealed system of the primary.
A couple of years ago, the capacity of the primary was 32 oz., and the tranny was 32 oz. Now the primary is 38 and the tranny is 28, but if I only use 28 in the tranny, it is down to the add mark on the dip stick on my Limited (it takes about 31, but the service manual calls for 28.). 4 Qts. of oil in the wife's tri will slightly overfill it. The best plan is a visual look at the level in the Primary and go by the dipstick in the tranny and engine.
I regularly service three Ultras, a 2012 Limited, a 2012 Tri, and a 2013 Tri. Each one is a little different in capacity based on visual checks and dip sticks.
Bill
#36
Internet myth using syn in primary makes no difference none not one bit if you want to waste the money.
#38
Are we talking primary oil or transmission? As per the 2011 service manual
"Add the recommended Genuine Harley Davidson lubricant as necessary....The transmission fluid capacity is approximately 32 fluid ounces (0.95 liters)
"Primary chaincase lubricant refill capacity"
38 oz (1.12 L) wet
45 oz (1.33 L) dry
changed all three holes yesterday, tranny will be over filled at 38 oz IMHO.
38 oz (1.12 L) wet
45 oz (1.33 L) dry
#39
38 oz (1.12 L) wet
45 oz (1.33 L) dry
38 oz (1.12 L) wet
45 oz (1.33 L) dry
#40
