What Exactly Does the Battery Charging Harness on the 2014's do?
Old 02-22-2016 | 11:32 AM
kydav's Avatar
kydav
Originally Posted by BadX
My dealer pointed out that a battery tender plug was on the bike from the factory now and its made into the wiring harness itself and not hooked directly to the battery. Can use it for heated gear and charge the battery. Had my plug tie wrapped to the bracket the seat strap screws to. Lost the seat strap but kept the bracket to keep the plug in a nice handy spot.
This is what I did. It's out of sight but still you still have easy access to it.
Rick
  #62
Old 03-27-2016 | 10:40 PM
AndyT's Avatar
AndyT
6th Gear
Originally Posted by Vernal
Welcome to the forum Andy.
You will be able to send and receive PM's, personal messages after 5 days and 5 posts.Go up to the Forums tab at the top of the page and hover your pointer over it, hover over General HD Forums then choose New member area. In the New Member area you can say hello to 4 other new members and have your 5 posts out of the way. When 5 days is up come back to this post and send me a PM, just click on my Forum name, Vernal and you'll see the choice. Then I can send you the schematics.
Bill
Hi Vernal,
I cant seem to send you a PM despite being a member for over a month now and 7 posts... I must be doing something wrong. Anyway, my email address is AndrewTurner(at)Chevrondotcom I really appreciate your help especially as I've flattened my battery yet again with this damn keyless fob :-(
  #63
Old 03-28-2016 | 08:01 AM
Magnut1's Avatar
Magnut1
I used to use it to hook up my inflator to inflate my air mattress when I was "roughing it at the Boogie" I just cut the cigarette lighter off and spliced on a pigtail.
  #64
Old 10-15-2016 | 03:14 AM
The Pawnbroker's Avatar
The Pawnbroker
A bit of an old post but I have a question for some of you. Has anyone been using the factory pigtail to power heated gear? Any problems? I have a 2014 Police Electra Glide and I have the service manual as well as the police bike supplement. I can confirm that the batt tender harness shows as coming off of the 20 amp P&A fuse. So it should work but I just wanted to see what people's experience has been.
Thanks.
  #65
Old 10-15-2016 | 07:25 PM
cdestuck's Avatar
cdestuck
Veteran: Marine Corp
It's coming off of a 20 amp circuit but it should have a inline fuse with a fuse that is prob about 5 amp. Look real close to the wire to see the gauge of the wire. To be a real 20 amp circuit the wire will have to be 12 gauge.
I fo the opposite, I have the heated gear and have that wiring mounted to the battery. I bought a adaptor for the tender wite and plug the tender into the heated gear plug.
  #66
Old 10-16-2016 | 09:13 AM
dakotared's Avatar
dakotared
Originally Posted by Hammz
Not from the factory it didn't. 2014's are factory installed. If your 2011 came with one, it was dealer installed.
Wow, I continue to learn new things on this site all the time. I always assumed the trickle charge pigtails on my 2010's were factory installed...
bill from tn
01-22-2023 04:22 PM
d-streetglidr
12-01-2013 08:18 AM
bbqbrisket
02-05-2010 05:24 PM
v8capt
05-16-2009 11:15 PM
hdzenride
Electrical/Lighting/Alarm
08-19-2008 06:27 PM
Quick Reply: What Exactly Does the Battery Charging Harness on the 2014's do?
