Advice Needed for Crankcase Breather Kit
I'm wanting to re-route the crankcase breather setup on my '09 RKC so that the oil mist does not enter the engine. It has the SE Stage II. So the AC backplate is different than stock. Id' like to route a hose downward and either rig a collector there or just vent to the wind. Does anyone know of a kit that will work?
I don't know of a kit but we just vented them down under the bikes for years. Also since it blows and doesn't suck there is no reason to put one of those weenie filters on the end of the hose. I know this isn't the politically correct way or "eco friendly" way in this day and age but it is the way it was done way back when
Mongo1958 (12-31-2020)
Bingee, I feel your pain. I have a stage one on my 05 Road King. I also grew tired of the oil dripping out of the air cleaner. And running the oil level low does not work. I simply bought a dual ended crankcase breather filter. Plugged the back of the backing plate. And ran the hoses to each end of the breather filter. I have it right behind the backing plate. can't even see it. Been using it this way for four years, and no problems.
I am not a fan of external tubes drafting oil mist down and in front of rear tire. Worse case situation you could belch oil out and go for nasty ride. I use the Arlen Ness Big Sucker plate which eliminates the oil mist into the air filter area and routes it directly into the intake. This still goes back into the motor, but no mist condition exists into the filter side. If you are trying to keep the crankcase mist out of the motor, the Big Sucker does not eliminate this. I don't think installing filters on the end of the breathers is a good practice. The breathers are designed to "draw" the crankcase mist or vapors out of the crankcase, assisted by the case pressure and any restriction on the breather tubes could allow crankcase products to collect in the motor and be more of a negative then pulling the mist/vapor into the combustion chamber.
No, this has nothing to do with performance, blow by, or anything like that. I just want to eliminate the buildup of crud in the throttle body.
