Kuryakyn EZ Brake
RE: Kuryakyn EZ Brake
Does yours look like this? Here is a site that walks you through the installation.
http://www.rollingthundercycles.com/...EZ%20Brake.htm
EZ Brake
Stock Brake
I'm thinking about getting one of these because with the position of my highway pegs I can just move my foot to the left and be on the brake pedal without lifting the foot up.
EZ Brake
Stock Brake
I you want the brake pedal to be lower & further forward then get the Kuryakyn #9039 or #9040. The difference between the two is the fitment only. I have had mine for about a year and it is MUCH better than the stock unit. Kuryakyn also makes just an extended brake pedal that is almost the same exact thing as the stock one.
[IMG]local://upfiles/5454/14BFDB21672E47D1B8E82B1B2E4D09C8.jpg[/IMG]
Here is a pic of it on my bike. I bought it after my foot got cought under the brake pedal in an emergency, That has not happened since. I swear by this. You must have it installed improperly if you cannot tell a difference bc my pedal is 2inches forward and 2 or 3 inches lower. I only have to move my toe to brake, much like in my car.
I have the EZ-brake on my ride. It's a huge difference on an older bike. Apparently HD made some changes on the newer ones , but, they still haven't made the stock brake as easy to use as the EZ-brake.
It was real uncomfortable to use the stock one, the EZ-brake is , as said above, just like using the brake in your car. It's right were it should be, never look for it. Perfect!
