Bearing removal/install tool
David
Here's everything you'll ever need for less than 100 bucks.
http://www.ebay.com/itm/HARLEY-DAVID...f#ht_467wt_806
Been working for me just fine. Same thing HD want $360 for.
lp
I also have a Pit Posse bearing puller set, works great. Installation tip: make sure the inner bearing races contact the inner spacer, or you'll put a bind on the bearings when the axle is installed. If the second bearing feels like it won't go down any farther, try the first one again. I've had a couple go in just a bit more after I could have sworn they were down all the way. If that spacer is loose, something is not right.
Just in case you didn't know, All ***** just repackages bearings made elsewhere. All the ones I've looked at were KML bearings - made in China. Moose Racing also packages the same bearings. They look pretty good inside, are double sealed on both sides, have what I'd call sufficient grease for one tire change - but, they're made in China... You can do better.
