Mileage stinks!
Then your tune is not as perfect as you believe. Stoich should only be the target in light load cruise range conditions. Everything outside of that should be mildly enriched and progressively enriched as WOT is approached. the AFR trace on a dyno run, if one was included, does not necessarily represent an accurate picture of the AFR condition across the entire map under actual operating conditions. If you have that much faith that your dyno operator/tuner has done a perfect job and you are getting crappy mileage, then maybe you just got a bike that gets crappy mileage. Hope you figure it out.
My high as been 47 mpg and my low is around 32 mpg. I've so far documented 67 fill ups and my average is 39.30. My gas mileage changes with speed more than anything, faster the sustained speed the lower it gets. If I'm running a steady 80+ the bike will never see 40mpg more likely around 36mpg or less. My bike as the 103 motor with a Stage 1 from Fuelmoto.
added: My 09 Road King with a 96 motor stage one easily averaged 42mpg and rarely dropped into the 30's mpg. I was so surprised by the difference I started to keep track and now consider it normal for this bike.
Guess I should go ahead and pull the trigger on cams and the jackpot header and have Ed at Dyno Difference up in Dallas tune it. When you're 200-250 miles from the closest reputable/respected tuner, kinda makes it a little harder. I've thought about going to an auto tune setup like the power vision just for that reason.
Actual mileage on odometer could be (is) inaccurate, but according to trip odometer we averaged 48.7 mpg riding mountains, towns,cities, and open highways...........
It's been this way since day 1....not out of the ordinary, it's the norm.
2008 with Xieds, Big Louie's w/ 2" baffles, Fullsac tru-dual conversion kit, and a RSD breather......
