Using Double Face Tape and Solvent is a method used for regripping golf clubs. Wrap the Double Face Tape around Handle Bar, coat with solvent, slide the grip on. Once the solvent dries, the tape adheres to the Grip keeping it on.
I don't use glue. I use electrical tape. Start at bar end and wrap towards control housing leaving a wide gap between wraps. Once you reach control housing continue wrap back out to bar end making a criss cross pattern then slide your grip on. If its too loose add a little more tape. I like mine just a little loose so that I can turn it to any position I want.
Cheap can of aerosol hair spray. Spray in grip, slides on pretty easy. When hair spray dries in a minute or 2 it is sticky and will keep grip from sliding, but not to difficult to move if needed.
I replaced my grips just this past spring.
The grips I got from HD came with a little tube of glue but I didn't use it. I didn't see the need and haven't had any issues.
