New hammock seat, 2014 limited
Anybody have one of these yet? Says not compatible with adjustable backrests. Is that really true? Looks like there"s an opening in the middle of the seat to accommodate a backrest, and I can't really ride without one, any way around this that doesn't include getting a seat other than the Hammock?
I had the gas operated backrest installed on the bike, would like like to be able to use what I paid for. I have the Hammock from my 2010 on the bike now, not perfect fit with the backrest, but better than nothing.
I have a Hammock on a 2011 Ultra with the adjustable backrest. It does not fit in stock form but is a really easy mod and does not prevent the backrest from being mounted normally later. Drill a couple of new rear mounting holes about an inch in front of the original backrest mounting holes. Then take a small bar plate about 1 inch wide x 2 inches long with two holes in it and mount it between the front mounting hole and the frame mount angle hole location. This change moves the backrest back an inch to fit the further back slot location in the seat. I've also heard the CVO Ultra backrest will fit. Hard to see in the linked photo with black bike. This is on a 2011 frame and assuming mounting locations on 2014 are the same.
https://www.hdforums.com/forum/membe...0327-00010.jpg
i hope your not upset that it is not to be used on the 2014... you paid for it for your old bike... not the new one.
Along the lines of what TNCarter said, it can be done, but requires some fab work.
This thread is about a Tallboy seat on a 2012 Limited, so the dimensions might be a little off from what you need, but you'll get the idea anyway.
https://www.hdforums.com/forum/touri...with-pics.html
