Cheaping Out on Brake Line
Not wanting anymore down time and looking at the front brake line to the master cylinder, it appears that if I move it to the bottom of the trees, I can gain at least 6" of length. That plus the normal play already would give me the length+ I need for the 12" bars.
I don't see any drawbacks to this plan, any comments???
Later over the winter, I can always swap it out for the 2 piece Magnum set up.
if it's the same brake line as on my Ultra Classic, then it will be stretched REALLY tight with 12" bars! i couldn't roll mine back hardly at all with the stock brake line. it was so tight i didn't feel comfortable at all! you can try moving things around and re-routing lines, it will give you some room, but not as much as the magnum set up.
i went with the Magnum 2 piece set up! MUCH MUCH better and easier to work with too! it only took 2 days for mine to come in once i placed the order.
hey, if you can re route it for TEN or more inches, that would be you're call. changed the routing on mine and gained enough to reach the bars.... might not be the same line then.... i had the brake line and clutch cable re-routed (clutch cable outside the fairing and brake line up the center)...
i put the brake line up from the center directly to the bars (you can see it in the pic of the front) and up the side, after i rolled them back a bit more than the pics it stretched tight tight. if there was 10 inches to spare, it wasn't on this brake line lol.
