What did your compensator sound like when it went bad?
Old 09-23-2013, 08:10 AM
UltraZac's Avatar
UltraZac
UltraZac is offline
Default What did your compensator sound like when it went bad?
I'm getting a bad knocking sound (it's loud) when I start my bike lately. Seems to be coming from the primary area. It will change with rpm until the motor warms up. It only makes the sound when it's cold. If I put my hand on the right side I can feel the vibration right through the bottom end of the motor. I can still hear it after the motor warms up but not as bad as a cold start.
Anyone that had their compensator go bad, what did it sound like? Getting ready to take it to dealer for warranty.
Old 09-23-2013, 08:21 AM
themensh's Avatar
themensh
themensh is offline
Mine was an :
'er, er, er...CLANK!.....blub, blub, blub, blub"
The 'er, er, er' is the starter turning over the engine. The 'clank'....is, well.....CLANK.
The 'blub, blub' is the engine running.
Chuck
Old 09-23-2013, 09:26 AM
UltraZac's Avatar
UltraZac
UltraZac is offline
Originally Posted by themensh
Mine was an :
Did it CLANK as you say, for a few seconds after start up?
Mine makes a horrible knocking sound for at least 15 seconds when I start it cold.
Old 09-23-2013, 09:42 AM
mikemnkt's Avatar
mikemnkt
mikemnkt is offline
that is what mine did when it was bad.kept grinding and making noise.id take it in if under warranty
Old 09-23-2013, 11:03 AM
themensh's Avatar
themensh
themensh is offline
Mine did not grind after the engine started....but once it did start....that Clank or Bang is a
WTF! moment. Usually did it once or twice.....then would start normal the next day...then do it again. Luckily bike was bought with extended warranty.
Be sure you ask for the screamin' eagle replacement.
Chuck
Old 09-23-2013, 11:05 AM
FLHR09's Avatar
FLHR09
FLHR09 is offline
Plus 1 - Be sure you ask for the screamin' eagle replacement.
Old 09-23-2013, 01:02 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Mine sounded like if you put socket in a coffee can and shook it.
Old 09-23-2013, 01:31 PM
jackja25's Avatar
jackja25
jackja25 is offline
Default Get it replaced
Mine went out a couple, three times under warranty. After the third time which was about 2 1/2 years ago and about 50k I have had no new issues with the compensator. The answer was my acceleration/shift points. When accelerating in 5th or 6th gear make sure RPM's 2500-3000. At least this has been working for me.
Old 09-23-2013, 01:40 PM
UltraZac's Avatar
UltraZac
UltraZac is offline
Sounds just like that.
Going to take it to the dealer after work today.
Old 09-23-2013, 02:06 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is online now
Received 18,175 Likes on 7,361 Posts
That's interesting. Never heard that before.
Quick Reply: What did your compensator sound like when it went bad?
