Anyone had a fatcat baffle out?
WD 40 each end of the baffle and get a soft pine 2x4. Drop (while holding it so it doesn't fall after the impact) the muffler tip first on the board, the baffle will start to come out. Then use a 2 and a half foot section of 2" pvc to drive out the baffle with a mallet (from the inlet side). If the pipe isn't hot, a 10 minute job max; including removing the muffler.
If it is a wrapped baffle it may not come out. they wrap clear tape around the backing and and it acts like clue. D&D will not guarantee that it wont damage the muffler taking it out even if you send it to them...good luck I beat the **** out of one then replaced the muffler with the right baffle....Good Luck
