Who cares about FM radio anyway?......I used the EBAY one just to get rid of the stupid whip antenna. As far as tunes....CD's, XM, or my IPOD all blow away FM.
Ummmmmm, I do. That's why I'm trying to figure it out.
Same antennae I have been using for several years and works great with great reception. At least as much as you can get with a hidden antennae. However I use a USB stick for music mostly.
It is not the HD antenna either , I have the same problem using an USB charger and I am using the stock whip antenna in the fairing. I put the stock whip back to the fender problem gone. I tried a different USB charger also but no luck
I went ahead and ordered the iSimple Polywire from Amazon...it was like $31. When I get it and put it on I'll let ya know what happens. I figured this was a safer bet then a direct wire USB.
OK, the iSimple Polywire came in yesterday and since the GOV saw it fitting to shut down and furlough me I decided to put it in today to see if it would help with the FM problem. It did. It's raining so I didn't bother to pull the bike out of the garage but inside the reception with the phone plugged in is 100x better.
I got the Polywire from Amazon for $31 and it charges the phone and has a jack for the radio.
I, for one, do.
I have the J&M fairing antenna and while it doesn't work any better than any other hidden antenna, it does work while a phone is charging.
I also have the HD XM module and it works fine while charging a phone in the trunk.
