2014 Speaker/Amp Upgrade. NICE!
Old 09-21-2013 | 01:13 PM
Bigg Lou's Avatar
Bigg Lou
Default 2014 Speaker/Amp Upgrade. NICE!
Ok, so I did the upgrade on my 2014 Street Glide Special. Installed the Boom! 6.5" speakers and the Boom! Amp. The volume isn't nearly as significant a boost as I expected but the sound quality at full volume is simply amazing. Don't know about that 1% distortion claim but the sound is crystal clear at full volume with bass & treble set to maximum. Of course at low volume the excessive bass doesn't sound so hot.
But all in all the upgrade is well worth it. Let me clarify that, buying the speakers and amp from Kutter HD saved me $203 from buying at my local stealership. That savings and the quality sound output makes the upgrade well worth it.
As a side note the amp installs really easily, truly plug in play but to do it easily and per instructions I removed the outer fairing, the wind tunnel, the seat, tank and wire trough. With easy access to everything then the amp was simple plug and play.
The enclosure for the speakers was another story. There are 3 Allen bolts that are easy to access from the front of the enclosure, on the side next to where the amp goes there are two torx screws that are simple enough to access but underneath that where the stereo is positioned there are three more bolts that have to be removed. 1 is simple, the other 2 if you don't have the right socket and extension forget about it, nearly impossible to get to those two bolts, I was really concerned I wouldn't be able to button it back up. Located the right socket and extension and finally simplified the removal & install. So food for thought if anyone decides to upgrade as well.
Old 09-21-2013 | 01:24 PM
lp's Avatar
lp
What ya mean Lou? That there is a lot of bass at low volume or that is none a low volume?
Great info BTW. Thanks for posting!
lp
Old 09-21-2013 | 01:35 PM
HDogg's Avatar
HDogg
I think he means the bass is too much at low volume level that it doesn't sound too balanced.I think you may have to lower the bass a bit at low volume and load it up at higher levels.And that the speakers don't distort even though he's got the bass loaded to max and the volume high.
Old 09-21-2013 | 01:36 PM
Bigg Lou's Avatar
Bigg Lou
lp
I was blasting the stereo at full volume with bass and treble set to maximum then dropped the volume down to see how it sounded. At low volume with bass still set to maximum it doesn't sound so good. Just to much bass, dropping bass down to about 75% and it sounds awesome at all levels of volume.
I've never cared for high bass output at low volume, seems to drown out the treble to much, IMO. Otherwise the system upgrade sounds incredible. Only thing is I expected going from 25 watts to 75 watts with the upgrade would gain me at least double to possibly triple the volume. I know the triple wattage doesn't truly translate into triple volume but I would expect a significant increase. I had built a custom fairing for my Dyna Fat Bob with 6x9's and a Kicker amp, you could hear me 3 blocks away on that bad boy. I remember people would turn around to see what was coming up the block long before I got to them and they were always amazed it was a motorcycle and not a car. Me thinks I have high expectations due to this custom setup I built. That said at full volume the Dyna setup did not sound even 1/2 as good as the new Boom setup.
Old 09-21-2013 | 01:49 PM
lp's Avatar
lp
That's incredible because you know the old system had no bass at low volume. I mean with treble still up you hear no bass really and that's no matter what setting you put it on...
Sounds like they really improved. That's awesome. Too much bass on a Harley... never heard that before!
lp
Old 09-21-2013 | 02:06 PM
HDogg's Avatar
HDogg
lp
I think you're comparing the stock old system to the stock new system.Buddy here has already upgraded the speakers and added an amp.That being said it's still nice to know there's such a thing as too much bass on a Harley.I'm assuming this is coming off the batwing speakers only.
Old 09-21-2013 | 02:12 PM
lp's Avatar
lp
No, I understood we are comparing old stock to a new radio plus upgraded amp/speakers. It's neat that the amp and Larger speakers are offered as an option from Harley which is different than previous years. It's a little more than just "boom!" speakers this time. People will pay a price for it but still neat we have the option now if you know what I mean.
lp
Old 09-21-2013 | 03:09 PM
Blitzburgh's Avatar
Blitzburgh
Did you also get the download from the dealership after you installed the amp? I had the dealer do my install and that also included the software update. Not sure what it does but it has something to do with the amp and the radio using it. On a side note after they did the download my playlists on my s4 dont show up.
Old 09-21-2013 | 05:03 PM
Sam2010's Avatar
Sam2010
I Was going to ask about the download from the dealer thinking it has to do with the line level input outputs from the raido to amp.
Old 09-21-2013 | 05:13 PM
jasnusc's Avatar
jasnusc
I was just about to ask the same question as I want to upgrade the stereo on my 14 SGS too! So how much was it after the $200 discount? And do you hook the power wire right up to the batter post or does it plug into the harness somewhere?
It would have been nice if it could have just all plugged in inside the fairing and not needed to run under the tank.
Quick Reply: 2014 Speaker/Amp Upgrade. NICE!
