Do I need a tuner?
Old 09-20-2013 | 04:05 PM
Guitardude's Avatar
Guitardude
The stage 1 download is pretty worthless. Spend the money on a tuner and the bike will run better, cooler with better mileage. The SERT is great but plan a good day at the dyno shop and spend the money on the software to tweak from there. Since you are buying a new bike, sticking with the SERT assures that there can't be finger pointing saying your brand x tuner caused a problem, and if you are ever in a place where there isn't a dyno at the dealer they can always flas you a canned map that will be about 90% correct for your bike and set up if need be.
Old 09-20-2013 | 04:15 PM
jmcdermit's Avatar
jmcdermit
Sweet....SERT it is....just wanted to make sure....the dealer is telling me not to get an auto tuner or rineharts if I wanna get the most performance
Old 09-20-2013 | 04:20 PM
dgdamore's Avatar
dgdamore
Get yourself a tuner. Better yet, go with wide band O2 sensors and an autotuner and you can skip the dyno time. Get a canned map from Fuel Mote or Dyno Jet and start riding and autotuning for best VE.
Old 09-20-2013 | 06:35 PM
jmcdermit's Avatar
jmcdermit
What is VE?
Old 09-20-2013 | 06:56 PM
BigTwins's Avatar
BigTwins
Heck... You need a tuner even if you leave your bike stock. That ECM needs to be massaged.
Old 09-20-2013 | 07:11 PM
dgdamore's Avatar
dgdamore
Originally Posted by jmcdermit
What is VE?
Volumetric Efficiency.
My recommendation is the Power Vision tuner but you will get a different opinion from anyone you ask.
Here is a great thread on the subject of tuning with the Powervision.
https://www.hdforums.com/forum/elect...-by-admin.html
Old 09-20-2013 | 07:19 PM
rooti's Avatar
rooti
why did you ask any questions here if your going to believe whatever the dealer tells u?
Old 09-20-2013 | 10:19 PM
ke5rbd's Avatar
ke5rbd
I am picking up my 14 SG next week and I am getting the VH pro pipe with the performance baffle and a heavy breather. Would I need to get a tuner, or will the stock map be good enough to make the bike run fine as-is? I don't want suggestions on which tuner...just asking if I need one or if I should put that money toward a color matched inner fairing!?
You will need a tuner. Make sure a tuner is available that has the new programing to work with the firmware on whichever you chose. The PV isn't ready yet. From what I hear if you do plug the PV in it won't be recognized by the ecm. I guess you have to be patient.
Old 09-20-2013 | 11:25 PM
jmcdermit's Avatar
jmcdermit
Troll.....who said I believed them? All I was asking is if I needed a tuner for pipes and air cleaner. If I can save several hundred dollars and have the bike still run good and safely, why not? I didn't ask for someone to be a smart@$$. The SERT was chosen because that's what their guys have worked with most and there is no other dealer close by that I trust that has a dyno. I decided on my own to get a vance and hines pro pipe instead of going with an 09 head pipe and slip-ons....thanks for your concern
Old 09-20-2013 | 11:33 PM
Uncle Chester's Avatar
Uncle Chester
Lol chill dude I'm pretty sure rooti is not a troll.
Look around your area too, pretty sure there are more component tuners than your dealer near you.
Quick Reply: Do I need a tuner?
