Sportster pulley on 07 streetglide
Old 09-21-2013 | 11:44 AM
pworks's Avatar
pworks
Thanks for the info. There's a lot of confusing part numbers out there. I already have the 30 tooth pulley but had to use a shorter belt. Hearing some of the stories about belts, I want to get in range to use a stock belt. Speedo error taken care of with PV. The 30 tooth made a huge difference. I think the 68 tooth will make a small difference but allow the use of a stock belt. I don't cruise much above 75 (too old and not in a hurry), so the rpm shouldn't matter.
Don
Old 09-21-2013 | 04:25 PM
jimsuver's Avatar
jimsuver
If you already have IDS can you use the hub you have and just get the correct sprocket ?
Old 09-21-2013 | 05:10 PM
DuraGlide's Avatar
DuraGlide
Yes. You need the 68T Japanese sportster pulley and the axle bearing for your 07 IDS application. I did this mod to both my 08's.
roussfam
14
02-02-2018 08:53 PM
Rimfire03581
05-20-2017 07:44 PM
scottdoege
01-07-2013 04:17 AM
goosehntr
11-13-2012 04:43 AM
speakerfritz
12-29-2011 10:16 PM
Quick Reply: Sportster pulley on 07 streetglide
