Cam Service Gasket Kit
Old 09-17-2013, 03:04 PM
DXHD $100's Avatar
DXHD $100
DXHD $100 is offline
Default Cam Service Gasket Kit
I am pretty sure I know the answer but I just have to hear it for myself. I will be doing cam up grade very soon I have found a $60- $65 difference in the cam service gasket kit prices. Other than the Harley name on their gasket kit I assume there is no difference in the quality between Harley's and the others on the market.
Old 09-17-2013, 03:10 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
You need 3 o-rings and a cam chest cover gasket....plus 2 inner cam bearings.....everything else is overkill....price them out separately and it will be cheaper then $60.....even if you buy them at a HD dealer.
Old 09-17-2013, 03:21 PM
DXHD $100's Avatar
DXHD $100
I have found the whole kit for $49.00 dollar
Old 09-17-2013, 03:36 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Still more then the price of what's really needed for the install but it's your money. I did two cams jobs on my bike within two months so I have some knowledge on what's needed. You have a cam removal & install tool? If not, PM me regarding a rental and I also have two new inner cam bearings if your interested.
Old 09-17-2013, 04:57 PM
dawg's Avatar
dawg
dawg is offline
Received 3,226 Likes on 1,841 Posts
Going through the top or using adjustable pushrods? Need pushrod tube o-rings unless you have pushrod kit. Need gaskets up top if going through the top.
Old 09-17-2013, 09:44 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
I got lucky when I replaced the tensioner shoes on my old 2004, I reused the cam cover and rocker box gaskets, no leaks at all.
Old 09-18-2013, 06:47 AM
NascarGuy's Avatar
NascarGuy
NascarGuy is offline
Give FuelMoto a call. I did my cam swap last year and found them to have the best prices. Quality was top notch as well.
Old 09-18-2013, 07:05 AM
Spur56's Avatar
Spur56
Spur56 is offline
I guess I will try and actually answer your question. Aftermarket gaskets are just as good as HD and many times actually better. James, cosmetic and others make gaskets.
Old 09-18-2013, 07:26 AM
DXHD $100's Avatar
DXHD $100
Thanks to everyone it sounds like my assumptions were correct.
Old 09-18-2013, 07:41 AM
pat1's Avatar
pat1
pat1 is offline
I really like Jame's gaskets. I like them better than the factory stuff and it costs less.
Quick Reply: Cam Service Gasket Kit
