Which Cam?
Which Cam?
Me and a buddy are going to upgrade his 2001 Classic to the 07 hydro Cam tensioner set up. He wants to change to a different cam with a little more grunt that is good for touring (low /Mid range)- and a little umph to pass when ya need it.
Stage 1 stock 88 motor - efi with pc111 (72,000 miles)
what do you have and how does it perform?
respect
UD
respect
UD
RE: Which Cam?
Kuryakyn TC-1 I putthat cam in my 88 and it ran great. Power everywhere. Pumped it up to 1550 with SE Hi-Perf heads and forged pistons, got tight and left that cam in. Mike Roland said the TC-2 would run better with raised compression and bore. I didn't listen and I am glad. That thing had power from idle and would stretch it's legs on the highway.
RE: Which Cam?
Did the Andrews 26G here - then went and did the 95" Big Bore kit. I wanted to change to a gear drive cam plus wanted a bit more low end torque - very happy with the results. I did no head work since most of my touring is in the 2-3K RPM range and the 2005 heads are actually pretty good as they are.
Received 7,737 Likes
