2011 Electra Glide Classic Exhaust
Bike and pipes are stock. Bought in March of this year w/66xx miles. Currently @ 87xx. Bike seems to run well with no problems. Yesterday I noticed that the left side inner exhaust tip area is blackened with soot(?), while the right is brownish. Any idea what might be causing that? Thanks.
Why would that be? I'd think that independent pipes from different cylinders would/should have equal pressure. Something to look into? Thanks.
...and if you hold your hands at the pipe ends, you'll notice less flow on the left.
as rpms ( and flow) increase, more exhaust will come from the left side as the right side can only flow so much on it's own
- this is not a problem, the design does keep exhaust gas velocity high throught the rpm range
mike
mike
Thanks guys. I stopped at a local shop, not dealer, to see what they thought too. I'm a stock is ok with me kinda' guy, but they are trying to sell me an upgraded pipes, breather, and ECM package for $2500. I understand that engines run better when they can breath; don't we all? But......, when dude said $2500, it took my breath away. If it isn't broke, I ain't fixing it.
